- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
OMG just removing the engine is turning out to be really tricky she does not want to give you ANYTHING. Every single bolt is absolutely stuck in there :headvswal they either snap off they are so tight or round off making them near impossible to remove :nono:.
When you work underneath her she either spits brake fluid, or power steering fluid on you. The drops grase and rust in your eyes in the hope that temporary blindness will make you give up for a bit. :eek:.
Yesterday it took me three hours to remove three bolts holding the exhaust from the back of the O/S tub. I could not get at one of them as the starter bolts were almost welded in so needed a good soaking in WD40. I managed to get the bugger out from above with a ring spanner at length doing like 1-50th of a turn each time she cut my hand :wack:. I finally got the bugger off though!.
Today started really well the two bolts on the exhaust at the back of the other tub came off no problems at all :hyper:. One at the top came out and the other came loose real easy. One of the last bolts came out about 4 MM then to my amazement just completely jammed solid :nono:. Would not go any further from the top, from below with a ring spanner with a socket... what a bitch and it would be the hardest one to get to as well. In fact she must of planned this to break my will on the very worst one to get to.
I wound it back in and out again until it jammed rock solid in the same place again. A spanner and socket would not move it :headvswal . This went on for two more hours until I could see no way to get it out.. I then had a brain wave maybe my air wrench would fit on it from beneath... yes it did but dooooh it just jammed in the same place every time I tried winding it in and out.
Brolly OX it then rounded the bolt off in the jammed out position. WTF was I going to do now. Blanco had stopped me once again, bleeding hands oil and brake fluid in my eyes and I swear she was laughing at me :eek:.
I got a hacksaw blade and tried invane to get it to cut through the exposed bolt. All I did was cut my hands further :headvswal. Then after making futile attemps with a blade on its own for another hour or so I then found a junior hacksaw and tied it to a long file at an angle. It took me another hour but my tool managed to squueze into the back depths of the engine and slowly saw that mother off.
This broke her will to fight :smash: I then managed to rob her of her exhaust, heat shield, prop shaft, and even drop the back of the gearbox. All she could do to me now was continue spitting fluid at me. Tommorow I swear I am going to rip that bitches heart out at last LOL. But she will probably crush me in the process or something.
