protoj · Yesterday at 18:48 1 day
Seemed to have developed a problem on the power steering, it feels too light and floaty at times and when turning at slow speeds it feels notchy like there isnt enough fluid in (but its to the correct level).
I have UK clocks fitted, there is not signs of leaks and the belt is good.
Any ideas folks?
