profec b spec 2
hello every1
just fitted controller
joined actuator to actuator with a t to the com part of controller
the 2 nipples under big main inlet pipes joined them with t to other side of controller
but what ever setting its on cant get more then about 10 psi
capped of everything else that was open
didnt un plug old boost solinoid wires just read this could keep at 14psi
any help on if i have done something wrong would be great
thanyou
Edited by Terry
word left out
also would any1 no how to get my controller to go to psi doing what says in manual and it just aint happening bloody cars
To make the boost controled read in PSI isnt easy, you have to follow the actions in the manual, but really quickly.
hello every1
thanyou
Standard problem with the instructions on these mate. They tell you to connect to one hole on the unit but it's the wrong one. Just swap over and it will work fine. Have a look at the post I have just put up of my enging bay and you will see how it should be.
Andy
just tried the thread cant find anything on an engine bay
also just got it into psi and its going 9psi
thank you
just changed pipes round and un screwed nipple on the controller and placed in other hole
still the same
around 9psi
aint that standard boost
i presume you have unplugged the oem boost solonoids?? as if you havnt it will boost to 9psi
i unplugged wires and removed all hoses and plugged nipples on big pipes
still the same
around 9psi
Strange???
the only thing i can think of could it be leaking boost
it runs really smooth when accelarating
on idle its smooth to, but get little pop out exhaust not a backfire almost like a missfire but sounds quite good but its allways done that
would it have to be a big leak to loose so much boost
i have put it to
set 100
gain 35
start boost whatever it went up to get it to go up but it wont still around 9 psi
Sounds like the boost controller is doing nothing so I would say you need to go back and look at how it's plumbed in. I think it's got something to do with the 3 holes and the instructions being wrong! This sounds like the same problem I had. If not it may be a faulty unit.
Andy
