Any way to make a NA faster?
Hi,
I would love to make my NA go faster. What's the best way to do this WITHOUT turbo charging, i.e. keep the engine normally aspirated?
Thanks.
Always drive downhil.
Or push it off a cliff. 0-120mph in 2 seconds :D
To Tune an Na it isnt worth the £££ for the gains you will get back. Ask hellraiser He got 260hp i think on an Na but he has spent a small fortune
Like the new Signature Daz!!!!!
Thanks mate, I`ve just been *****cked for having it toooooooooooo big :D
See ya soon when i pick the sub up!!
Daz
supercharge it :dance:
ok, serious answer for you, although as said its a lot of money for little gain in comaprision....
Headers
Chip
induction
Exhaust
Suspension
Underdrive pulley
Lighten Rotational Weight Components!
Propshaft (Can get a 1piece Prop made up)
Lightweight Flywheel
Other Ideas
High Lift Cams also good on NA cars (Dont know how well on a Zed though)
And the ideas that others have mentioned!
rear mounted single turbo same as the one that was at jae, lovely install and 350 on standard na engine, was very clean install and available as a full install
But that would envolve fitting a turbo when he said WITHOUT !! :p
the amount it will cost to make a n/a faster will mount to more than what a twin turbo car would cost you?
True I did miss that bit :D
It would still retain the initial grunt of the na, the turbo is at the back out the road, engine still remains easy to work on and would be cheaper than trying to squeeze another 40hp out of an na without some sort of forced induction
Slick Pete,s the man to talk to , he did a few things to his shorty and that didn,t hang about :bow:
