Located a whole load of boost leaks including one at each end of the balance bar. I've put new seals on it but it's still blowing, can't understand it. How does everyone else seal it up completely?
Also, I can't understand why it should be blowing past the nuts (lost one of the dome nuts), assuming the seals are sealing there should be no leakage here. Assuming they're not sealing I'd expect it to leak out of the sides rather than the more difficult route past the stud and nut (!?)
Perhaps the balance bar flanges are warped through previous overtightening?? I'm going to resort to some flange sealant for the time being I think.
Any reason why I shouldn't use some silicon hose between the balance bar and the clutch booster check valve?
Last thing, does anyone have a pair of throttle body intake hoses they'd care to sell? don't want to buy the whole set of 4 as I have dump valves on custom lower hardpipes.
Hi guys,
Thanks in advance for any help.
H
