September 12, 200917 yr hello everybody let me pick your brains i put in 1.2mm jets in made no diffance to car i did not put chip in yet i thought it should have made some diffance am i wrong
September 12, 200917 yr Do you have an aftermarket boost gauge ? if the car is in safety mode then boost jets wont make a difference. The same can apply if you have a boost leak.
September 12, 200917 yr Author Do you have an aftermarket boost gauge ? if the car is in safety mode then boost jets wont make a difference. The same can apply if you have a boost leak. yes mate i have after market boost gauge chected ecu got a 55 no leaks it reads the same as car boost gauge rufley 6.5 psi car gaug only goes to 7 anyway :(
