A/T Diagnostics
Hi All, done an A/T diag/fault code readings using Conzult and got all these:
THROTTLE POSITION SENSOR SIGNAL
VHCL SPEED SENSOR - A/T
TURBINE SENSOR
ENGINE SPEED SIGNAL
BATTERY VOLTAGE OR FLUID TEMP SENSOR
I then deleted all these, took for a drive and all came back?? does all this mean they cant be read by the autobox ecu? they arent very clear like ecu codes?
Regards Andy
anyone? my gearbox is defaulting to 1st and 2nd gear only, would these faults cause that?
