passenger electric window stopped???
hi guys,
just today for no reason as far as i can see the passenger electric window has stopped working??
the window will not work from the switch on the drivers door or the passenger door switch tho the drivers window works fine???
are the windows in different fuses or is this proberly the window motor has just decided to stop working??
dan
When you press the window button can you hear a slight clicking/humming sound??
if you can that means it has power to the switch? and its normally the motor
Loads of window motors on ebay from breakers, try nissan 100nx aswell cause they fit
Daz.
Agreed. If you hear a click the power and relay is working, the motor had seized on mine. Piece of cake to change
Has the connector to the passenger side switch become loose? this will also stop the window operating from drivers side.
Apologies is this sounds obvious, but you would be surprised how many people do this - Check the little button on the drivers side window switch is not pressed down, that turns off the passenger window !
when pressing either switch im not hearing anything!
legrath i will check this button you mentioned in the morning, i may well have touched this button as only a few days ago i had the door card off to repair the door release handle, ill check in the morning and let you know!!
hi guys,
dan
Did you find the problem, this just happened today to me but both of them. on the drivers side if i hold the switch down it will move every 10 - 30 seconds a small amount clicking each time
yea i sorted mine, i had just clicked the lock button in without realising so a simple fix for me!!
it sounds like your motor is giving up the ghost to be honest!!
sounds like its trying to work but hasnt got the power or torque to work properly, a new motor should fix it mate.
tho some1 with more knowledge than me may have another solution soon!
this happens to the best of us! including me! :rofl: :slap:
aii the newbie zed owning classic fault is back :rofl:
Ive done that as well!:o
dan.;)
