August 27, 200917 yr car WONT idle at the mo. im thinking theres a vacuum leak somewhere, going to do a test onit this week. just checking that this wont cause any problems tho, the 2 hoses that go to the EGR solenoid, ive removed & blocked off (at both ends) reason was, one of the pipes went to nowhere (on the side of engine, but nothing attached to) and i needed some hose for the washer jets, so cut & blocked the other off. no problems by doing this? if not theres a vac leak i presume as WONT idle on its own, needs blip on the trottle
