Greddy Profec B2 Boost Controller Info needed
As in the title im looking for info on any ones settings for the profec b to compair as well as your engine mods/spec, plus what power did this set up achive for you.
I have the Greddy Profec B2 and shared my settings with Cburto and they worked well for him (although his were in PSI and i work with BAR) lol
Here's mine its profecB 2 and im running JWT Ecu, Zorst and filter (Custom management soon though)
Low Boost (around town boost) setting:
Gain - 15% (slow and gradual)
Set Gain - 0.3bar (only 5psi but you dont need boost pottering around town)
Max - 0.35 (no need to go into major boost if you do give it some welly)
Warning - L.15% (this Cuts the boost by 15% so will go back to 0.3 your holding boost)
Peak - This is the highest recorded boost you have hit
Peak On/off - Have it On just so you can see your not overboosting although more for High Boost
High boost settings:
Gain - 28% (Fast spool up big kick but runs out of puff around 5300 so you dont high rev)
Set Gain - 0.8bar (12psi as i dont want to be maxing out my Injectors everytime i boost and Cause everything to go Super Lean and then Bang)
Max - 0.9bar (as explained above)
Warning - L.15% (will cut me back to 0.8 bar which is reasonably safe)
Peak - My highest recorded is 0.97bar and Injectors are Maxed at 1.00
Peak on/off = ON
This is a good starting point, had these settings on the Rolllers and Coughed out just shy of 350bhp at the fly with no issues what so ever!Obviously still had another few PSI to go higher on boost if i wanted to but id rather be safe than sorry for Bhp Figures! guy was really happy with everything said Dont change a thing :)
Cburto said he was getting his on the rollers at some point and will obviously adjust the Settings if needed so will be good to see his results
Please be aware that if your car explodes (pretty safe settings o you should be fine) i will not be held responsible and these are Car Setup and Engine Condition Dependant as my engine only has like 50k and New Turbos) (Said that just to cover my own arse in case but you will be fine)
Edited by Munny975
Thanks for replying to the thread Munny all info is appreciated, does any on else have any ifo to add to this tread im sure it will come in handy for others too
i posted up my profec setting ages ago...do a search you'll find others as well that may be good for you.
chris
yeh i have some settings i did at some point many moons ago
