Does anyone know where i can buy some 2inch brake duct hose off the shelf? Im fed up of buying online and having to wait a couple days for some poxy hose. You cant buy this stuff in and builders depot or plumbing shop, ive tried everywhere why is it so hard to find ffs.... I ordered the wrong amount and now i need more and im really peed off... where the hell do you buy this stuff from? anyone know?
Anywhere in london is good for me....
if you happen to know then your a saviour....:bow:
The stuff in builders/plumbing supplies can handle the heat ?
they dont have the correct flipping size, they are all idiots there, something so simple so hard to find why is this.... plumbers hose is too thick anyway, i need 2inch thickness, theres is normally 4inch wtf.
it doesnt have to be heat resistant as its not close enough to get hot as ive made a coupling attached to the caliper directing inside the cavity of the disc.
Are you after the stainless copex type flexi stuff used for flues ??
its the flexi hose with the wire running around it.
yeah that expanding stuff is not what im after and i needed 3 metres, anyways its ok ive just used some plastic tube and joined the rest on so theres enough lenght, not what i wanted to do originaly but its fine.
