Anyone recommend a good high fill primer?
As above. I'm smoothing the stonechip, currently using plastikote Spot filler and primer. Just wondering if there's a better one?
I'm guessing you are using spraycans when you mentioned plasticote? Not going to get a high build primer / filler in a can unfortunately...
Do you have access to spray gun / compressor? If you do I would do a couple o coats of 'Reface' and it would be smooth and sexy.
Don't use high build primer as a filler on the bumpers, just get rid of the finish!
As Si says just persevere till its completely smooth,time consuming but the end result is worth it :)
