Cruise control wiring question...again!
Right, desperately trying to re-fit the disabled cruise control. The CC was disabled by the previous owner who had fitted an after market steering wheel.
Now, the control box and the wiring to that is there, the on/off switch is there.
I have cruise control button pad which I am going to mount somewhere, but I can't for the life of me work out where the wiring for this to plug into should be? I've had a good rummage around under the column and there's only wiring going to 3 connectors, one for the ignition, one for the indicator stalk and another for the HICAS sensor. Does this connector for the HICAS sensor incorporate the wiring for the CC? Because I can't really find anything else.
There are 2 soldered points on the left hand side of this, a grey and a yellow wire are soldered to. Is this is???
Can anyone help because I'm starting to get a bit hacked off with the setup and how it's all wired up.
Maybe one for Jeff?
Edited by FunkySi
The cruise control connectors and the horn push share actual cables ( yes mad I know).
The connector from the cruise button clips into the large white/ black assembly behind the wheel, this also does the hicas angle sensing, maybe this assembly has been removed ?? failing that the cable looms run down the steering column and terminate about half way down, find the horn one and thats the one you want.
Will take a photo for you tomorrow and mark out which is is and pm it back to you.
Jeff
Thanks Jeff.
You talking about this?
Edited by FunkySi
