August 17, 200916 yr just taking a look at the engine bay, the 2 tubes you insert the jets to (as per this guide) http://www2.zhome.com:81/ZCMnL/PICS/boostJets/boostJets.html where do they run from? i think i have 1 of the tubes plugged with a screw, as i think it went to the re-circs, but removed the recircs so just blocked it up. i think they need to go to the ones from each wastegate? same location each side?
August 18, 200916 yr Author i found the tubes in question, they run from the actuaters, then go to the metal intercooler pipes. ive got the tubes from the actuater, however ive blocked it at the other end? as i was under the impression it just runs down the side of the IC pipes, feeds the re-circs. is this correct? or do they need to go to a vacuum?
(as per this guide)
