Hicas
my hicas inner arm has play and needs replacing..
but can i get the bypass...
will this mean that i no longer need the arm
is it a cheaper option>?
cheers
In general the lower priced bypass units do use the hicas arms and the outer bushes so if they are worn out you still need them replacing as well as fitting the bypass unit, so not very cost effective.
Jeff TT
okay cheers jeff..
do you happen to have any good inner hicas arms in for the drivers side??
if so how much?
cheers
Will have a look for you tomorrow and post back.
Jeff TT
^^^^^ What dave said ^^^^^
but you need to get some way of looping the pipes that go to the PAS pot.
i got a hi-cass elimination kit for sale if your interested?;)
dan.:D
Thats easily solved Mikey.Will tell you when you get yours on.
Yeah, its called buying the fitting from Z1 :mac1:
I've got the Stillen kit on mine but am seriously thinking about the Driftworks total elimination kit... Think JimmyTT did a write up with Pics when he fitted his and I have to say it looks the dogs danglies!
just rebuilt my back end with poly bushes and drift works eliminator, kit is A1 and comes with every thing you need. you`ll save a hell of a lot of weight reckon 30-40lbs when every things off. by pass is easy, took my local engineer 10 mins to knock up, tighten your banjos and top up your fluid, no effect on steering feel. just remember to get 4 wheel aligned after..... get 2 straight black lines on road now, lol
dan.:D
pm sent
