rear hicas rack swap bleeding
Hi all.
i just got a non-leaky rack, and [lan to fit it tomorrow.
Anyone know the bleeding procedure+ what fluid is best?
cheers!
Its is normal power steering fluid and is fed from the same pot in the front. To really bleed it properly you need it hooked up to a Conzult which can replicate the Hicas action when stationary but I think if you keep turning the steering from full lock to full lock whilst bleeding either side of the rack, you should be able to get the air out. Make sure you keep the pot topped up as it does goes down rather quickly.
