bad earth??
hi just got my 1st 300zx and the problems have started lol :rolleyes:
its an import (if that helps)
the clock kepps needing to be set and the heater always goes up to 25 (hot)
also the central locking has packed up
any ideas are these common problems ?
cheers,
Not to sure , but check all the fuses out , there is a thread as to location, hope this helps ,
Blown fuse in the drivers footwell will cause that, its the one for audio I believe.
yes thats done it cheers but the clock and heater numbers stay lit all the time is this right?
sorry for all the questions ;):D
They go out when the key is removed, at least they should.
no theyre staying on any ideas?
Does the interior light also stay on or not work at all? only other time I have seen this problem it was to do with the fuse box in the footwell, water runs down there from leaking targas and messes with the wiring / fuses.
interior light works as it should, we did have quite a lot of rain at the weekend tho i'll check all the other fuses does this mean a new fuse box then?
I would start with the easy stuff, check all fuses, there is also an earth there that can become rusty, take it off and clean it up, see what happens then.
where abouts is the earth ive checked all the fuses theyre ok but couldnt see the earth,
If you remove the plastic trim is just below the fuses, you wont be able to get to it from just taking the flap off above the fuses I am afraid.
nice 1 cheers :duffer: hopefully it'll sort the problem :cool:
right found the earth and it was fine no signs of any corrosion i gave it a bit of a clean as i was there but still hasnt solved the problem
the interior light works as it should, the only other thing i think it could be is the turbo timer? would this effect it ?
