Bleed clutch - myself this time as garage crap
car is all back together and running now :D
however havent got clutch, garage were struggling to do it after the gearbox/engine swap.
ive seen this video on you tube which sounds easy, just wana make sure if this diagram applies to the Z aslo?
on the Z i know there is another bleed valve, by the HICAS thing by the drivers headlight.
can someone tell me which bit i need to do 1st? ive searched and read loads of pages but still confused,
can sum1 do a very quick step by step what to do? i still have the standard setup and dont really wana potch fitting braided lines, :cry:
(3 mins 12 is the bleeding part)
I did the bottom one first then the top and then both again. Mine was really stiff at first so rocked the car in gear with engine of as I think it had binded. Pumped the clutch again and the started the car, went straight into gear!
