Availability of headlamp connectors?
Hi Guys, think I've finally narrowed down the cause of my repeatedly blown fuse to the driver's side headlamp, main bulb connector. It's a bit mashed up, I've left it disconnected for the last few months and the fuse has remained intact.
Anyway, I need to find a replacement connector, can anyone point me in the right direction please? It's a 1990 jap import. I don't want to do any kind of conversion if I can avoid it.
TIA!
RobH
Rob,
I believe the connectors are not widely used on any other cars (other than JDM cars that use H3C bulbs) so your best bet is to either
(1) find a good one off a breaker and splice it into the wiring loom, or
(2) cut the offending connector off and replace with two spade connectors
Other than that I wouldn't know where you'd get a new connector from.
Dan
Ok, cheers. Spade connectors it is then....
H
