In memory of Mandy
Fitting rear adjustable camber arms
As above, anyone know if I just need to undo the bottom bolt of the rear shocker remove from bracket and slip the arm between the shocker and bracket? Or is there a better way of fitting?
Yea, got the front adjustables to put on as well and then have to find a reputable outfit to set it all up. Was hoping zedworld would be able to do this but last I heard Jeff hadn't got the equipment sorted. Don't want to just take it to a tyre fitting shop because all they can do is a basic tracking job. Any other places around Lincs, Yorkshire or Notts that can be recommended? Another problem I have found while poking around is the dreaded rust around the rear end of the sill, which in its self is bad enough but my car has side skirts on and I guess when I take it to a welding shop they will want to take them off before welding. Has anyone had this work done without having to rip the side skirts off?
theres a realy good place at the bottom of wigwam lane in hucknall nottingham has a really good 4 wheel aliment set up beegeevinz had his done there and has been happy with the job. Has changed owners since but i now the family and there a good bunch of lads i think its called robinhood travel but carnt be too sure hope this help stew
Thanks for that mate,just a warning to anyone, been struggleing to fit some decat pipes from 2fast2cool from ebay to be told by them that they will not fit auto cars:mad: does not state in the advert I am well pi$$ed off, managed to get them to fit but the are touching the gearbox casing. Will road test saturday to see if they make a noise.
lol they defo will make some lovely noise lol.....
get a long bar in there and bend the fookers so they dont touch.
