stud removal rear wheel
need a bit of help with this guys please:rolleyes:, progress so far, wheel off :nelson:, caliper ,bearing nut off,now the problem is how the bloody ell do i take the last part off to remove the stud? help mucho appreciated.
Don't go any further. you should be able to knock the stud out now, there should be a place behind the hub where the stud will pass out the back of the hub you just need to line it up.
Paul
okey dokey, what about installation bud?it will be a bit of an arse trying to get that back in!!
Pull the new stus in with either a nut /or washers and the standard wheel nut .Make sure the nut or nuts are bigger than the stud ie thickness.:)
