July 20, 200917 yr when im driving my amp cuts off, no fuse blows, its as if when i put my foot down theres a power surge or something and it turns my subs off?? any one had this problem or know what it is??
July 20, 200917 yr um, think maybe your alternator/battery. does it only happen when your music/subs are turned up loud?
July 21, 200917 yr Author nope, i read another post on a google site saying that if its a big amp, which mine is 4000 watts, then i need a thick poer cable as it need more power, so i take it cus my power lead is like a string of spaggetti, that when i put my foot down there isnt enough power getting to the amp maybe?? and so amp shuts itself off.
July 21, 200917 yr ahh there a bit tricky to set up but thats wot u want bud stores the power the amp needs will have a look 4 u see if theres any where that shows u
July 21, 200917 yr http://www.caraudiohelp.com/car_audio_capacitor_installation/car_audio_capacitor_installation.htm
July 21, 200917 yr hope this helps bud and read the bit at bottom about charging the cap very inportant and if u dont have the resistor u should be able to get one from maplins. so just hope it helps cheapest and easy way see as u already have the bits
July 21, 200917 yr cap is easy, just have posotive from the battery to the + on the cap, then another seperate wire from the + on the cap to the + on the amp (so 2 wires on the +) the - on the cap just goes to the earth of the car then.
