Hi guys
Fitting the passenger door card, noticed there must be some kind of threaded fitting which holds the top of the interior handle to the door. The trouble is the bodyshop must have removed the fitting when they sprayed them. Only found it was missing after fitting all the rest of the door parts. Would any one have a quality picture on the inside of a door so i can see what the fitting looks like?
Regards
Kev
Thanks for your help
I've already seen the fitting guide, but the thread fitting for the top bolt of the passenger handle is missing. need a picture back of the door so i can see the fitting i need to order from Nissan.
Regards
Kev
Here you go, just taken my door card off for you.
Picture shows both the upper and lower passenger handle fixing points on the door...
Dave
