Electric window question - One shot lowering
Does anyone know, or have seen a switch panel converted to one shot lowering for the passenger side? I know the rocker switches are different size, but is the main switch itself the same size as the driver's one?
I am just considering the possibility of converting the passenger window switch to a one shot like the drivers' side.
TBH Si I'd of said that you would have to convert all the wiring as well! Plus fitting a control box the same as in the drivers door.
Also, as far as I'm aware, the drivers side switch unit is both switches in one block, screwed to the underside of the fascia, if that makes any sense?;)
Yes not too hard, you will need another door module like in the drivers side, this is the unit that electronically gives you the one touch operation.
A small amount of additional circuit work would be required (2 x relays ) to enable the auto one touch operation as the passenger switch does not have the extra contact that the drivers door one does, however it would give one touch operation for the passenger window from both the drivers and passenger position.
The module has 8 contact points
1) 12v+( battery)
2) 12v ign
3) 0v 12v
A trigger one touch UP mode ( earth pulse)
B trigger one touch DOWN mode ( earth pulse )
C trigger Extra button contact ( relay switch-over connection required ) between A / B trigger
P1 Window motor UP output supply
P2 Window motor DOWN output supply
You could reduce the extra relay by one if you only want one touch on down.
Hope that helps
Jeff TT
Thanks Jeff! I can get my mate to do that, doesn't look too bad. Will taken him about 5 minutes I'd imagine!
Could you not get from the USA to make it easier?
How would that work Murt? Their switches are opposite. I'd stll have to convert one of the switches to one-shot.
