error code 13
hey have searched but to no avail. im getting code 13 ( temp sensor) when i check ecu now.. any help as to where i would locate this? thanks
Is it the one in the water pipes at the front of the engine ? Try cleaning the connections they go green.
No 14.
1. Air Intake Hose
2. Turbo Hose
3. Power Steering Reservoir
4. C.A.S (Crank Angle Sensor)
5. P.T.U (Power Transfer Unit)
6. Windscreen Washer Bottle
7. Engine Coolant Tank
8. Fuse Box
9. 6 Coil Packs
10. Oil Cap
11. Radiator Cap
12. HICAS Solenoid
13. Radiator
14. E.C.U. Water Temperature Sensor
15. Dashboard Water Temperature Sensor
16. Fuel Filter
17. Brake Fluid Reservoir
18. Clutch Fluid Reservoir
19. Brake Servo
20. Air Filter
21. Throttle/Cruise Control Cable
22. TPS (Throttle Position Sensor)
23. Passenger Side Stock Boost Solinoid connector
24. Driver Side Stock Boost Solinoid connector
25. Driver Side O2 sensor Connector
26. Det Sensor Connector
27. Passenger Side O2 sensor Connector
28. Fuel Damper
29. Fuel Pressure Regulator
30. Balance Bar
thanks.. found it.. my car is dead as a dodo anyways n wont fire.. but thought i would address this problem.. having looked at it .. it appears the plug is stuck on and one of the wires is well.. not even connected.. hmmm.. looks ****ed to me!
