**MODERATION EDIT**
im thinking of converting to manual
how much should a kit of bits cost
Edited by GUMBALL3000
EDITED .. ADVERTISING AN ITEM WANTED IS NOT ALLOWED AS A REGI-USER
i would have thaght it cheaper to by an entire car tbh,
just by a shagged car with no MOT or damaged,
you NA or TT?
You can pick up a manual conversion kit for around ยฃ700 to ยฃ800 pounds, its the fitting that costs unless you want to do that yourself. It is not difficult and pretty straightforward with the key to success being to make sure you have everything, every nut and bolt etc., We (me & son) did it in a day starting at 9 ish and I was driving it home at 4.30, but with no reversing lights.
sorry to jump on thread but so that me and original poster can find this kit can you point us to a link? :hyper:
easiest optioon dont be so silly an buy an auto in the 1st place :p
na seriously tho, manual unleashes the power a lot more, youl be glad you did it!
ive bought 2 automatic cars, but had all the parts from a donor car.
its a tt.
can you use a na box- i know the clutch/flywheel is different.
i dont want to buy another as i have just bought this one and it was too good
to turn down.
i have no problem in doing the fitting.
a fluid change and filter clean seems to have sorted my auto but i would still prefere to change to a manual.
i also have a navan shifter fitted which should get back some of the funds and id hope to get a bit of cash back for the auto.
