help and advice needed while heads are off
hi all.
my uk tt manwel go a bit hot and the head gasket on drivers side went pop. so ive stripped it down with the intention of replacing both head gaskets and also while i am on i would like to replace the smoking turbos.
so the questions go
which head gasket should i use?
which turbo seals to use given the fact its decatted with a larger exhaust
i see there is a lot of speak of removing egr gear
and a direct feed bypass for the turbo water feeds.
also i am contenplating repalcing the intercoolers and possibly the turbos but what a rough idea of what the experts might suggest as sensible mods, i can see that this could snowball very easily given the chance.
all help appreciated
cheers
rich
No posts to show
