Help - turbo oil feed return pipes
Can anyone tell me what I need to do to replace the oil return pipes from the turbos? I bought these pipes a long time ago and attempted to fit one a while back but abandoned the idea after removing the clips and realising that I could not get the hose off. Is there any easy way? Cheers.
i think the only way you're going to do it, especially with OE pipes on there, is to cut them off.
you could even unbolt the oil return "hard pipe" from the turbo but, then you will need a new gasket.
The problem is not getting the old ones off, its getting the new ones on.
The new pipes are very flexible . warm them up in hot water then you can bend and twist then in between to two hard pipes and your done.
daz.
Rent a Japanese woman with small hands :xxx:
Thats the evening sorted, but what about these turbo oil feed pipes :rofl:
daz.
Good tip.
Thanks for replies, some good tips. Especially the one about the Japanese woman. Does anyone know where I can rent one :)
