ECU questions
I have a jap NA manual. I'll soon be dropping in a TT engine from a uk auto, but keeping the car manual.
Will i be able to use the ECU from the uk auto if it is chipped?
Second question, what the feck are the other 3 boxes next to the ECU?
Scott
Scott
One is Fuel ECU and i think the other is ABS?
One of them is the ascd(??) or cruise control, assuming you have it that is.
Yes, will work fine
Jeff TT
Depending on version/spec under the footwell you have :
Engine ECU
Autobox ECU
Cruise Control ECU
PAS/Hicas ECU
Fuel pump ECU and ABS ECU are both in the back of the car
Cheers for the replies guys.:bow:
Scott
Yes, but, you will need a boost controller if the car is going to be a TT, as the NA ECU does not have the Boost Solenoid Control Valve circuitry.
the UK auto ECU,
is it NA or TT?
i think people are answering yes, to the fact you can use a UK or Jap ECU, and the fact that auto or TT.
but the new ECU, regardless of Jap/UK or manual/auto, will HAVE to be TT.
NA wont provide enough fuel for the TT engine.
the UK auto ECU,
is it NA or TT?
All UK cars are TT ;)
yup, going for Greddy Profec B spec II
