fuse or worse?
seeing as my problem last night occured (post hmmmmmmmmmmm)
i have again tried to get some luck getting the keys out. I have noticed that the battery still sparks when you connect the connections so there must be power in the battery.
but trying every buttopn and switch in the car returns no results.... hoping a fuse has blown but surely there are multiple fuses and i should have some form of basic functions e.g overhead lights, etc.
could it be that i have blown all the fuses to have absolutely no function.... as it stands the zed is dead.
is there a master fuse that distributes power to the smaller fuses? i am severly hoping so
Yes - there are a bunch of fusible links in the relay box and also a circuit breaker feeding the ignition circuit side of things.
ok i will try the circuit breaker. where about is it located if yo don't mind :-)
i have rang MJP regarding fuse links just now and they are cheap.
also,,,, is there any reasons why the PTU S2 would cause an earth or blow fuses?
not enough insulation? or was the PTU buggered........... ?
