Brakes
Lots of questions about 350 and Skyline GTR calipers but couldn't find any that answer this
There are Brembo ones (gold/red) but there are plain black non Brembo ones, are these any use and better than stock?
Mitsubishi Evo Brembos are very good value. I bought a pair of fronts for £150 delivered with all shims, pins etc and they have done hardly any work. An engineer is making up adaptor plates at the moment for me. Readily available to buy on http://www.lancerregister.com/index.php
HTH Anthony and if you want to see mine when they are fitted in the next week or so let me know
M
dont bother with the rear evo brembo I believe the piston is slightly smaller than the 300's standard caliper piston, fronts are good though
I've been offer R32 GTR front brakes (discs and calipers) for £100, they are 296mm discs so only 16mm bigger. Are these worth for a tempoary upgrade until I find some Brembos?
TBH i probably wouldnt bother but thats just me. Get on that site I mentioned
Mike
M
Which EVO were they off and what discs are you going to use?
from evo 4 upwards I believe. Krsmayo fitted evo8 calipers and has diagram and measurements for the brackets. They are bigger than the GTR/350z setup and a lot cheaper.
Edited by Yowser
Mine are off an Evo 8 but as David says from a 4/5 upwards they were the same calipers until the 9. Im using discs off a 350z that are 324mm.
Weekend after next i'll be fitting mine hopefully so if you like pop to Newport and have a look to give you some idea's.
