hi my car seems to put out blue smoke whet you really boot it.but other times it doesnt smoke at all can someone help mark
Turbo seals matey! Means you need to get your turbos referb'd or get new ones!
Does it smoke when you have your foot planted or when you lift off, could be pcv valves/breathers, worn valve stem seals and lots of other things
the seals are normally on idle and will chuck out smoke, not on boost :confused:
  • 10 months later...
Time to do a compression test. Could either be ring glands or if you're lucky, it'll be PCV valves. Doesn't sound like turbo seals though.
car only done 40000 miles
Means nothing if it had had the boost cranked up and was running lean.
Get the compression check done to eliminate it.
  • 3 weeks later...
Dude, you need to find out what's wrong with your car before taking the speed limiter off!
Boost might have been altered in a previous life unless you know the history of it in Japan. Most JDM cars have been clocked also.
Edited by FunkySi
are you 100% sure its blue?? might be a case of running rich.
Mine kicked out all sorts of crap on full boost. turned out to be my lambrda sensors and i also cleaned the pcv valves and job done :)
