How much does it cost to refurb recircs?
anyone had this done? I have goosehonk on both slightly so was thinkin it may be cheaper to replace with bov's any help appreciated
Not sure they are repairable, i've never heard of anyone doing it.
You could probably get a used set for next to nothing anyway.
cheers might go for the bov's then it's an auto by the way.....
ps sub boxes are ready whenever you are dude ;)
I suffered from Goose honk when I had 0.8mm tips fitted, but found this was considered to small making too much boost so removed and fitted 1mm tips. Goose honk disappeared with them.
point being, you could try reducing the boost slightly...
Just a thought:)
oh poop I just offered to buy some bov's instead cheers for the offer I may take you up on it if these don't happen ur star
Just a thought:)
happens on stock boost too when opening a can of whoopass :D
Jeff was going to do a write-up as to how they are assembled, IIRC, there is a way of sorting recircs and it involves fitting some sort of relay device/switch?
