Boost gauge problem
I took the car out last weekend and all was fine, havent been using the turbos much (as in not raced anywhere), took it out on monday and the boost gauge now only goes half way between 0 and +14 so 7 whereas before it went right to +14.
Whats broken this time? :(
Sounds as though the ECU is restricting extended boost as something is out of tolerance. Could be anything tbh - do an ecu check and see if there are any fault codes as a starting point.
