hi ya i have a problem with my 300, it dosent allways start when hot it was suggested that it could be the ptm sensor but when it done it earlier to day i checked to see if it had a spark and it did, plus the car is a series 2 so it has the better ptm sensor anyway, so im at a bit of a loose end with it, can anybody help???plus it sometimes crunchies going in to 5th gear especially under power, but all the other gears are fine is this likely to be the clutch or could it be the gearbox? thanks...
