Hi, just got myself a 91 SWB manual N/A. Love it 2 bits & it drives smooth. Just in2 the 2nd wk & sidelights & hedlights decided to stop working? ive done the obvious. . Relay, fuses, & changed the switch & still Zip! Heres the thing, if i turn sidelights on i get nothing right? i turn headlights on & get. . main beam. If anyone can shed some light on the matter (no pun intended) it wud be appriciated.
Regards
Matt
A fuse has blown mate ;)
Next to the accelerator pedal there is a plastic cover - pull it off and it will reveal some more fuses - its one of the top ones - a 10amp IIRC.
HTH :)
Hi Matt and welcome to the club :D
Firstly, please don't use text speak, it's OK you don't get charged by the amount of letters used here ;)
Secondly, when you say you've checked the fuses >> check this out, exactly the same as what you are describing http://www.300zx.co.uk/forums/showthread.php?t=56717&highlight=sidelights+main+beam
HTH, if not do a search for 'sidelights & full beam' and there are loads of threads to look through. I have seen this exact problem before and it is almost always one of the fuses
Dave
It's a fuse mate... Drivers footwell by the loud pedal... Top row third from the left if memory serves... Hth
Thanks guys! i had a feeling about fuses in the cab! i did check out panel under steering colum. . . well i was close. Sorry for using txt speak just habbit lol. Will get some pics soon & should be @ the Jap show santa pod in. . . June? If anyone wants to meet.
Welcome to the Club Matt..... :)
Thanks, i think these cars rule! bottom line, the best looking car for there money,make a nice sound to :)
