May 26, 200917 yr Hi All My right exhaust bank has begun to churn out the blue smoke. Can you please advise me: What spares I will need once I have the engine out. Where I can get them from the UK. Should I be re-conditioning the turbos entirely ? How do aftermarket replacement turbos compare price wise to re-conning the original items. If I were to have a garage undertake the work, how much do you think it would cost? Many thanks Rob
May 26, 200917 yr have you got a budget in mind? as it might be worth the extra dosh for new tubs not saying reconning them isnt any good but just the long-term view really
May 26, 200917 yr Author Its all going to be on the never never so moneys no object ! I dont have a budget as yet. I wanted to cost the different options then make a call.
May 26, 200917 yr speak to http://www.turbodynamics.co.uk for a quote. I've used them many times and highly recommend them if you decide to get your stock turbos reconned in the UK. They can also offer upgrade options. Its been over a year since I last used them, but from memory it was round 700 the pair for stock rebuild with 360 bearings, and upgrade stages ranges from 1100-1600 the pair. You can purchase rebuild kits and DIY them. Its not something I have ever done myself though. I would cry far too much if I put the engine back in and found my DIY rebuild skills had not gone to plan. The alternative is to purchase stock or upgraded turbos from the U.S - http://www.z1motorsprots.com, http://www.conceptzperformance.com You can also purchase the CHRA (the centre part of the turbo) and fit them into your existing housings, which is a cheaper option than buying the complete stock turbo. Exchange rate not so favourable these days though. Edited May 26, 200917 yr by Yowser
Hi All
Many thanks
Rob
