Oil Pressure?
Hi all just wander what the oil pressure should be when cold, hot, idle and running? mine seems to be sitting at 0 nearly all the time, what could cause this problem??
Regards Andy
The most common reason is the sender unit; replace it and the gauge will perform as before.
It is expensive though - around £80 for the part.
Richard:)
believe me you would know your cars is not running right with no pressure.
  • 3 weeks later...
are aftermarket gauges hard to fit??
I've managed to fit 5 of the buggers, so I'd say no. The oil pressure sender for aftermarket gauges connects to a sandwich plate between the oil filter and engine. Then it's just a case of running a wire to the gauge and providing power.
