A/T Check Results
Done the AT check just now and got one long flash and 9 blinks = engine revoution center circuit fault.
No idea what this is.. bad good? expensive to fix?:(
Small sensor that provides the gearbox ecu with internal gearbox speed, essential for the gearbox to work correctly.
The good news is the sensor is fitted on the outside of the gear box on the passenger side about half way down so can be changed fairly easily, a good used sensor would be ok to keep the cost down.
Jeff TT
Jeff TT
That is good news :)
Do you have these sensors in stock?
