Where is the air con re-gas point on my Z?
There are two points low pressure and high pressure, both in same area you can fill from one if you must but really to do it correctly you need access to both so you can evacuate the system and pressure test and then vacuum the lines for 30 minutes or so. When refilling remember to add a few cc of mineral oil or the compressor bearings will not last very long.
Jeff TT
Edited by JeffTT
Can you fill from either ports then just brought 2 conectors from ebay to fill with 134a gas was going to try to do it myself with a can.
dont screw them adaptors onto the R12 valves to tight..not even half tight or they will fvk the pin up on the R12 side...i bought the same things for my rangie and after my fun and games had to replace the pipe work:(
So do you think hand tight will be ok will it not leak.;)
no finger tight is plenty believe..they have a rubber seal and once filled you take em off anyway
