Speedo stopped working....then started again
Just took the Z out, didn't notice it at first, but looked down and saw my Speedo was sat at 0 and the milometer wasn't moving (everything else working fine). Turned round to take it back again and looked down and suddenly it started working again.
Are there known faults with speedos doing this? I'm going to take the binnacle off in a second to check that all the connectors are snug and 'clipped'.
  • Replies 30
  • Views 740
If you have the time mate, maybe worth taking it out and renewing all the joints then its all done!
duff speedo, i have had two sets of uk clocks now as the first set i bought had this problem.
Mine are working are working though. It was litterally for about 5 minutes.
Yup. I drove it around all of yesterday, no problem. Took it out again this morning to fit the new LED backlights. Refitted, all worked fine. Was just this evening.
mine did. drive along then bang sat at 0 mine ended up flicking all the way to 180 and staying there!
did you connect it all properly, might be a lose wire in the back??
you were speeding really weren't you:tongue:
mine is a little lazy upto 25mph.. it sticks to begin with.. then it flicks up really fast...lol
They are all block connectors. They simply snap into location.
try and give it all a bit of lube. im sure you will have some in your bedroom somewhere :tongue:
Hey Si
Try giving all the connectors a blast of electrical cleaner. If its persistent you can always take the clocks out and put them in your old case.
Si i had this a couple of weeks ago vijay had it spot on with a worn section on the worm gear on the motor..may be worth a look and if its ok a thin coat of grease may do it
Problem identified/solved. Took off the binnacle and it appears that the connectors may have a dry joint in them rather than the clocks themselves. I had to give them quite a hard tug to initially pull them out of the old JDM clocks, so may have disturbed them a little.
Wiggled them around to watch the coolant gauge flicker, so realised it was probably that. Made sure the wiring was secured. Took it for a drive up the motorway and back, over some rough-ish roads and not a single peep from it. So it looks like it was that.
how long it take to fit the clocks si? just curious as got to do it myself someday and congrats on fixing the prob
Got that sorted quick!
Thats what she says :rofl:
Take about an hour to take out and replace :)
I feel sorry for her - my woman dont say that to me :D :dance: :rofl:
Yup. I hate not having things working. Once you've taken the dash apart the first time, it's so easy to pull it all apart the second. I could probably take out and refit the clocks in about 10 minutes now.
@ 8ace, took me about 35 mins the first time I did it. It's easy enough to do. 2 screws holding the binnacle on, this then pulls off. Unscrew the pod switches (2 screws each side on both sides). Pull out from bottom and up. Unclip connectors. Unscrew 2 screws inside each pod, either side. Unscrew 2 bolts at the top of the dash shroud and pull the lot away. There are just 2 screws at the bottom of the clock unit one either side. Unscrew these and the clocks are ready to be pulled out. You then have to unclip the connectors from the back and it's out. Very easy job if you do it in the right sequence.
