top idler pulley, the one that sits onto the end of the inlet manifold, does anyone know how to get it off? in the tech manual it shows only was to remove inlet manifold is to remove this pulley and it's stud bolt.
i can get the pulley off no bother but not sure how the stud bolt is secured as the manual doesn't cover that,
so basically how do i get the bloody stud bolt out? lol
any help appreciated
cheers
Ryan
its a straight forward screw in bolt to the lower plenum. if you want to remove it, best way is to put 2 nuts on the stud so they lock, then use the inner nut to undo it with
nice one cheers for the reply! i figured it was that, have tried using 2nuts (ooh er) on the end of the stud but it just doesn't seem to wanna budge!
are the replaceable if i chew the thread on it?
