help with autogear
need help with autobox, from pull away it will only change once and will not go into any other gears hence high revs, i have tried the autobox diagnostics test from z world and it has one long flash and ten short ones.. cheers
Edited by brett300zx
if you do a search for "autobox problem, failure, not changing" etc you'll get countless similar threads, first thing to try is changing the oil but failure is a common problem it would seem.
