Draining coolant...?
Where is the best place to drain the coolant from on my 1992 UK tt Z?
And what capacity does it take to re-fill?
Thanks, Dan
There's a small rain plug on the drivers side but that will take ages to empty. You can undo the bottom hose which is on the passenger side :)
Taking the rad hose off will only drain the rad and the very top of the engine.Youll need to remove the drain bungs on the side of the block.(bottom of engine either side in front of engine mount brackets).The engine needs 9ltrs of coolant to fill it according to the w/shop manual.
Hiya Joel,aint even given it any thought bud.Japfest is on the horizion and im still not sure if im going.
