When first started and before reaching normal temperature my Z has started coughing and spluttering. It's OK after 5 or 10 mins but just worried it may get worse. It has only just started doing this. Any ideas chappies?
I would first check the temperature coolant sensor.
I once had a coil pack connector which was a tiny bit loose which had the same effect. Just push down on each one (it's the connector which you can touch which is above each spark plug).
It's a 20 second fix if it's the one you need - fingers crossed !
Dave
