Thread Sizes!
Hey Folks, bought some Gauges (Oil Pressure, Temp and Water Temp)that i will be installing in a couple of weeks, will be doing a HOW TO Write up for it as iv not found one! Looking at which bits i need to buy for the Gauges to work along side my Stock Gauges. Got all the Senders just need the extras then can install them! (Will be DIN GAUGES)
Oil Temp Sensor. Need the Size of the thread for the Sump plug!
Water Temp. Water Adapter Size to fit in the pipe (Saves me measuring it up)
Oil Pressure. Size of the t-piece needed. Had a look on the forums found a few posts saying where to buy them i would like to Double Check the sizes before i buy!
Many Thanks
Munny
Although i can't offer any advice , i look forward to the guide thread as i'm gonna be doing this also soon , got the gauges etc , just need pillar pod and senders
chris;)
Yeah but i believe you can leave the old one still in place!So 1 slot for Old Sender and 1 for new as well!
Just made a call to a few company's , to source senders etc for the gauges i have ,
there first question was ...........
what's the thread size's, so could do with knowing this also,:)
thanks Chris
Edited by ck300z
Apparently Demon Tweeks know the thread sizes so will give them a bell tomoz as doesn't seem like anybody knows... lol! The thread size for the sender (what you need) should be on the box or in Instructions! Usually 1/8 but best check with the supplier of the Gauges!
I got the gauge's of a fellow member very pleased with em' just minus the sender's
plus pm on the way:)
Size of the sandwich plate thread is 3/4 unf 16! fits a 1/8npt sender and has 4 slots! i have metal water pipes so measured the silicone hose and was 42mm so will be buying a 38mm Water Temp adapter! Found a clip rubbing on 1 of my pullies too :( nudged it clear though phew!
Thanks for this mate :bow:
still waiting for that chap to get back to me after sending model details etc
wow :eek:, good job you noticed the clip
Chris
