whats the wire coming from the clutch pedal?
im doing a auto to manual conversion,
i have the clutch pedal and booster etc out of the car,
but theres a wire/switch coming from it, and goes to the loom of the car?
does this need to be connected when i put into the auto car?
didnt see anything on the guides about it? and woudnt have a clue where to splice it on the loom of the auto car?
Cruise control cut out switch, connect it in series with the same on the brake pedal.
Jeff TT
I think that is the cruise control cancel switch. There is one on the brake pedal as well.
As soon as the pedal is touched, it should be set so the switch 'breaks' and cruise control is canceled. I would have thought that it should be in 'series' with the brake pedal switch so if either pedal is touched the circuit is broken and CC unlatched.
didnt know the car had cruise control?
i asume theres something on the steering wheel, but i have aftermarket so nothing on there.
so im fine not to connect it back up then? (dont want/use creuise control)
car will still work/start etc without it ye?
Not all had cruise control. You will have a cruise control button on the Right hand pod if so.
its fine leaving it disconnected.
