i've got a noise coming from the center consol between the targa tops.took the cover off and its a fan ,seems to start spining as soon as i turn on.what is it? the wire to it looks big enough for it to be important but buzzy rattley noise driving me mad.antone got any ideas how to fix it?Cheers
p.s. where is best place to get a spoiler ?
give it a spray with WD40 first and see if that cures it :)
cant advise spraying highly flammable liquid on live (or soon to be) wires unless your me:duffer:
use switch cleaner far better and safer - used it on all my PA equipment on faders, gains and tired old switches breathes new life into them!
what is the purpose of this Aspirator fan anyways?.. does it actually do anything beneficial?.. i'm just assuming from what I have read that it does something with climate control?.. so does it detect what the temp is at the roof lining in the cabin and say for example you want.. 20 degrees.. and it detects it as being 15.. it will increase the amount of hot air around the car or something??.. hope i'm not hijacking the thread, but I'm assuming we all have these in our cars and it would be good to know what it is / does :D
Cheers!
which quotes on the side highly flammable! wd40 would be perfectly fine . been used to drive out moisture from electrical connectors in engine bays and the like for years!
disclaimer : i have never had a problem , use at your own risk!
Cheers!
Correct. The fan draws in air across a temperature sender, which feeds information back to the climate ECU regarding current cabin temps so it knows wether it needs to raise or lower the temperature to get it to the requested setting.
