light problems
got back from a quick spin in my zed today and noticed that my headlights only work on full beam also my sidelights do not work and my rear lights do not work. checked the 2 15amp fuses under the bonnet and they are fine. any advice on this one as my reversing lights and brake lights work fine.
Top row third from left 10amp red fuse, side light feed, main beam works as a default.
Usual causes of blown fuse is when work been done stereo head unit / area or side light bulb at the front gets water ingress in the light unit.
Jeff TT
HI jeff, tried the fuse, all is now good. thanks for your quick response.:bow:
HI to all that helped, tried the fuse, all is now good. thanks for your quick response.:bow:
