In memory of Mandy
gearbox help please
Couple of gearbox related questions for you.
I have a manual NA.
If i fit a TT engine i will need to buy a TT clutch and flywheel. Are there any other changes needed or will this all go together no probs?
Also, i have a one piece Z1 propshaft. If i change to a TT gearbox, will the propshaft still fit?
Fly wheel is bigger ot the tt, you will need to keep your na fly and clutch or get a tt gearbox
Or just grind out the bellhousing on the NA box and pack out the starter motor:)
Cheers guys
If i were to fit a TT box, would the prop still fit?
You would need TT front half and NA rear half, thats if you were keeping the NA diff
It's a one piece Z1 prop. I thought the manual boxes were the same where they meet the prop?
They are.:D
i went googling:
"The NA and TT have the same 5 speed transmission model #, same splines on input and output
shafts, etc. and the housings are the same except for one small difference. The spot where the
starter mounts on the bellhousing on the TT is machined a little differently so that the starter will
properly engage the slightly larger diameter flywheel and so that the flywheel teeth won’t scrape
the inside of the bellhousing. You can use an NA 5 speed in a TT but you just have to shim the
starter out a little with some flat washers and sometimes grind a little out of the inside of the
bellhousing so the TT flywheel will fit inside."
and:
"The TT clutch has a larger contact face, a stronger pressure plate and a slightly larger diameter
flywheel. You can use a TT flywheel in an NA by shimming out the starter but can’t use a NA
flywheel in a TT without cutting down the spot where the starter mounts to the TT transmission.
You have to use a TT clutch assembly with a TT flywheel and the same with NA because of the
way the pressure plate bolts to the flywheel. The TTs also included a clutch booster assembly
because of the stronger pressure plate. The clutch pedal and master cylinder were different
because of a vacuum assisted clutch booster inside the firewall. The booster included two plastic
tanks for vacuum storage also, one under the driver’s fender and one under the clutch master
cylinder and a network of hoses connecting them all. Because of the clutch booster, the clutch
pedal and master cylinder are different between NA and TT but all the slave cylinders are the
same. You don’t have to add this setup when doing a conversion (a lot of trouble) the clutch pedal
will just be stiff but it’s not at all a problem in our opinion."
i went googling:
Yep. Thats just what I told ya!!!:bow:
